What would you do...
Operator1
477
NC
If you were driving along one night, and the lights in your instrument cluster quit working, so the next morning you check for codes, and get these:
P0381 Glow Plug/Heater Indicator Circuit Malfunction
C0040 Right Front Wheel Speed Sensor Circuit
C0110 - Pump Motor Circuit Malfunction
U1000 - Class 2 Communication Malfunction
U1096 - Loss of Communications with IPC
U1300 - Class 2 Short to Ground
B2600 - Daytime Running Lamp Control Circuit (BCM)
B2610 - Passenger Compartment Dimming 1 Circuit
B2625 - Display Dimming Pulse Width Modulation (PWM) Output Circuit
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
First two i get a lot, dont know why. Rest are probably tripped because of the instrument cluster crappin out. Gm has a ysb/recall on that....might wanna see if your truck meets their criteria for getting it replaced.
Operator1
477
NC
Thanks for the suggestions. I looked for rubbed wires and the like today, haven't found anything yet. Did figure out that the indicator light on the 4wd buttons quit, and the power side(?) supports on the driver seat as well. Also sometimes the radio doesn't quit when you open the door, and sometimes it does. Seems like something a loose ground would cause, I guess I'll keep looking.
