What To Twin With?
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
What would be the best charger to twin with a 65-66mm turbo?
My two thought are a S480 and the S510? What do yall think?
On second though the 510 is rather large, what about a GT55?
717
s465 that is on your truck?
i know of at least one truck that runs a 64mm/88mm setup (4088/4718) heard rummors of another running a 66m/80mm setup
a GT55 is a 91mm wheel. yes that would work with a 65mm pending turbine housing. but more of a WOT race setup. a 67-70mm wheel would probley work better
s510 is a 110mm wheel? never seen a map of the wheel
vortecfcar
No longer a member
Jun 28, 2007
167
There are a lot of S400 variants between the 480 and 510 that should probably be considered. My first thought is an S85 or S88 if you want to tip toe past necessary. Both are on a T6 and would provide the air to push very big numbers
9,905
151
Are T6's a lot harder to spool than T4's?
Or slower to spool I mean??
