Yeah me again, with electrical. Again :|
So I'm almost done my LBZ to 2012 Avalanche transplant, but I've run into yet another problem. so the J1939 lines for LBZ are all self contained in the engine harness and only go between the ECM TCM and GCM. @kidturbo gave me some insight on how to use an LMM ECM to convert from 1939 to GMLAN which seems to work on paper, however the LMM is also self contained in the wiring harness, commands and information travel to the instrument panel and BCM via Class 2. The diagrams for the Avalanche are similar regarding the Class 2/LoGMLAN and high speed GMLAN, except EVERYTHING has both, so I've got 4 pairs of high speed coming out of the firewall coming from the Avalanche BCM that originally connected to the Avalanche ECM and TCM, with nothing to connect them to on the other side. what do I do with these? the wiring schematics show them simply spliced together all over the place so should I just connect them back on themselves? should I leave them cut?
on top of that I have a dark blue wire from the avalanche labeled "accessory wake up" going to Instruments, BCM, ECM, and TCM with nothing like it on the Duramax side. Any insight on to what these wires exactly do or even just a place to find the info myself would be greatly appreciated.
And one more thing; after reading the wiring diagrams until my eyes bled and trying to figure out how CP shutoff works I'm under the impression that as long as the engine is wired correctly, I can simply cut power to the run/crank relay to shut off the engine even if my Avalanche body I'snt 100% sorted out. I'm just afraid of testing it, and then having the engine run away because it doesn't have all of its inputs to the body set up. Am I stupid or letting paranoia get the better of me or both?
