I've been gathering parts for my build and well pistons are the last thing I need before it heads off to the machine shop.
Goal is for around 850-900hp. Truck is not a daily driver but will see some street time on the weekend and heading to the local track also.
Turbo setup will be an s480 over a 68mm 4094. Stage 1 SoCal heads, EDP stage 2 alt firing cam, Carrillos, main & head studs, dual fuelers & 100% over injectors are the main parts to the build.
So it seems I have a few choices of pistons I've been looking at. Fingers oval bowl, mahle race cast, or just C&C lb7/lly pistons. They'll all need .075" valve reliefs put in them due to the cam. Wanting to be somewhere in the lower 16:1 CR.
i know you can't go wrong with fingers or mahle pistons but if I can get away with a lb7/lly pistons id rather run them. Very rarely will it be on the max effort tune. I'll mainly keep it around 700hp or so which is more than enough for the street.
