What pid's?
PAT
EASY DAY
Aug 21, 2011
1,100
your back yard
Ok. So I have been trying to get my truck tuned all day. Can't get ahold of my tuner. Called several times to see what pid's I should log so I can send them to him.
I've been waiting around for a call back. I have a V2 that I'm borrowing so I'd like to do this in as much of a timely manner as possible.
So here it is.. tuning is for a stock charger and 60 over sticks. All the stuff for the stock charger has been turned off.
Truck now has an 85% cp3 and the new turbo. What pid's should I log and send out to get this thing tuned properly?
I'm not super efi live savy. So sorry if the question seems elementary to some.
fctry286
WhisperMax
Jul 30, 2010
254
San Diego.
PRI CAPTION DESCRIPTION VALUE UNITS MIN AVG MAX PARAMETER SYSTEM
1 FRPACT Actual Fuel Rail Pressure 5156 PSI 4692 7535 25898 GM.FRPACT Fuel
1 MAF Air Flow Rate From Mass Air Flow Sensor 4.99 Lbs/Min 4.59 9.70 62.28 SAE.MAF Air
1 CYLAIR Air Mass Per Cylinder 0.83 Grams/cyl 0.77 0.91 2.74 CALC.CYLAIR Air
1 BOOST Boost Pressure 14.2 PSI 14.2 15.6 37.0 GM.BOOST Air
1 FUELRCALC Calculated Fuel Rate 7.9 mm3 0.0 15.7 100.0 GM.FUELRCALC Fuel
1 FRPACOM Commanded Fuel Rail Pressure Regulator Current 1086 mA 316 1027 1189 GM.FRPACOM Fuel
1 FRPACOM Commanded Fuel Rail Pressure Regulator Current 1.086 A 0.315 1.027 1.189 GM.FRPACOM Fuel
1 FRPCOMM Commanded Fuel Rail Pressure Regulator Flow 6592 mm3 0 9642 47736 GM.FRPCOMM Conditions
1 FRPDES Desired Fuel Rail Pressure 5076 PSI 4931 7529 23061 GM.FRPDES Fuel
1 FRPERR Difference Between Actual And Desired Fuel Rail Pressure 80 PSI -2899 6 2837 CALC.FRPERR Fuel
1 ECT Engine Coolant Temperature 158 °F 158 174 189 SAE.ECT Temperature
1 RPM Engine RPM 682 RPM 616 1130 3288 SAE.RPM Conditions
1 IAT Intake Air Temperature 95 °F 82 95 117 SAE.IAT Temperature
1 MAP Intake Manifold Absolute Pressure 14.2 PSI 14.1 15.6 37.0 SAE.MAP Air
1 MAINRATE Main Injection Fuel Flow Rate 6.9 mm3 0.0 14.4 79.7 GM.MAINRATE Diesel
1 MAINBPW Main Injection On Time 458 us 0 566 2939 GM.MAINBPW Diesel
1 MNINJTIM Main Injection Timing 1.0 Degrees -2.0 3.5 24.0 GM.MNINJTIM Diesel
1 DMAX_TRQ_DMA Maximum Engine Torque 912 Ft-Lbs -90 688 926 GM.DMAX_TRQ_DMA Diesel
1 PILOTRATE Pilot Injection Fuel Flow Rate 0.9 mm3 0.0 0.8 0.9 GM.PILOTRATE Diesel
1 PILOTBPW Pilot Injection On Time 288 us 0 227 298 GM.PILOTBPW Diesel
1 PIINJTIM Pilot Injection Timing 8.5 Degrees -1.4 10.8 38.5 GM.PIINJTIM Diesel
1 FUELQ_THR_DMA Throttle Base Fuel Flow Rate 0.0 mm3 0.0 11.9 100.0 GM.FUELQ_THR_DMA Diesel
1 TP Throttle Position 0.0 % 0.0 12.4 100.0 GM.TP Throttle
1 BOOST_DMA Turbo Boost Pressure 14.3 PSI 14.2 15.8 47.9 GM.BOOST_DMA Diesel
1 VSS Vehicle Speed Sensor 0 MPH 0 24 86 SAE.VSS Conditions
cafryer
May 5, 2011
1,074
Utah
[Parameters]GM.BOOST_DMA=1,610GM.DSP5_TUNE_DMA=1,4533GM.FRPACT=1,695GM.FRPDES=1,698GM.FUELQ_MAIN_DMA=1,704GM.MAINBPW=1,767GM.MNINJTIM=1,803GM.PIINJTIM=1,831GM.PILOTRATE=1,833GM.TP=1,882SAE.MAF=1,953SAE.RPM=1,974SAE.VSS=1,989
PAT
EASY DAY
Aug 21, 2011
1,100
your back yard
Thanks guys.
The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does its own oil change. It's just a pity the management system is so ****ing temperamental.
