So what do you all think I should do next? I floated a lot of ideas over the past year, but more than a few of them didnt pan out. Was fun trying though.
You all knew my goal this past year, and thanks to all of you, Im only .10 away from the "stock turbo" top spot..and God-willing, that should fall next spring. But what about the unthinkable....an 11.9x sec run? Possible? Crazy?
My initial thoughts are that I have enough fuel, CP3 and reg are keeping up just fine, although maybe an LBZ pump might help?
Suspension should be fine, although rear QA1s are a possibility.
Obviously, airflow needs improving now, but in keeping the "stock turbo/engine" goal, its not going to be easy .
So to that end, I think:
1) uppipes are a must.
2) 3.5" downpipe
3) Not sure if larger I/C piping would help.
4) PnP the turbo, but keeping the same wheels/geometry.
5) adjustable wastegate
Thoughts? Ideas?
2) 3.5" downpipe
Thoughts? Ideas?
