what lift pump?
05DirtyMax
Jun 26, 2008
12
Plant City,Florida
i was just wondering what lift pump i should go with?i thought about going with maybe the air dog150 or would i be better off to go with a ppe and save myself some money?
paint94979
Beer Nazi
Sep 18, 2006
11,715
PPE outflows all other pumps except for the FASS 200/Air Dog 200. for the price a PPE pump is second to none.
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
many here talk about pressure.....what about volume? my super diesel high volume lift pump only flows 6 psi or so after my secondary filter but it doesn't drain down the gauge at WOT even when my rail pressure is dropping. hmmmmm.
WSUcowboy
500 club baby!!
Aug 7, 2006
512
Spokane, WA
MITUSA, I will be doing a full write up on the install when I am done, I am going slowly over the next couple of days, should be finished up by next weekend.
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
Why do I not see many Fass systems? Do people not like them? Just curious.
There is a longer story behind part of the reason we deal with AirDog over FASS but it mostly boils down to price. A FASS is the same design as the AirDog with one element missing that makes the AD seperate air better. I like the way the AD mounts and the kits they come with better. And to top it all off they are cheaper. Haven't had any problems out of the dozens we've installed or the ones we've sold.
Cromaglious
Jun 27, 2010
Temecula, PRoC
I just went with a cheap Auto Zone E8012S for $32 9# pump on a box stock 02 CC/SB LB7 Auto. First time I put it in I stuck it on the fuel return line, took another trip to Home depot to get the hose barbs for the 7/16" fuel line. I used to loose prime after sitting level for more than 30minutes.
So I'd suggest you go with the PPE since it doesn't take that much pump to fix the problem.
So again the Fuel SUPPLY line is the BIG one, the smaller 5/16"ish line is the Fuel Return..
Robi
2002 Chevy CC/SB Dm Auto 4x4
1997 Cadi Sedan DeVille Northstar
1996 Ford E350 Cargo 302gas Auto
1995 Ford F150 EC/LB 302gas Auto w/o top gear. Around town truck.
1990 Ford F350 7.3 IDC CC/LB Auto 4x4
1986 Chevy 1ton SC/Utility Body 350gas 4spd
1997 Bobcat 863
1995 Toyota 3K# Forklift
S Phinney
4,008
Quncy, Fl
The Airdog is a very nice and well put together kit. I had the TTS pumps and they lasted about three years. They ran but wouldn't pump fuel. The AD 165II is what I use now and am happy with it as well as the noise. It is the quietest pumps next to the TTS and Kennedy pumps. It also has a Lifetime warranty.
Alligator
Nov 9, 2006
1,919
N. Idaho
I've sold and installed a bunch of both Fass and AirDog, and prefer AirDog personally. I find that the AirDog II is the best of all worlds, with the demand flow pump and adjustble fuel pressure regulator. And like Dustin said, the mounting setup on the AD is cleaner and easier than the Fass. Not knocking the Fass setup at all, as I run their HPFP currently on my Dmax (and have for the last 4 years w/o issue), but I will be installing the AirDog II 240 gph unit when my new motor goes in later this summer.
wdino73
735
55
Versailles, Ky
I"m running a Fass, cause I liked thier stickers, adds atleast 20hp,
Seriously, I've got about 18000 miles with it, no problems so far, but IMO I think the Airdog is a better product..
