Question: What lift pump to use on LBZ?
kenny
kennydiesel
Mar 5, 2009
319
washington state
Which lift pump kit would you guys recommend to use for the DIY guy and why would you use the kit you recommend? Thanks again everybody. All your insight is greatly appreciated.:D
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
I really love my Airdog!
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
i have heard good things about the airdogs . i run the fass 150 and it has worked great so far .
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
AirDogs come with everything needed to mount, plumb and wire them. Including a draw straw (fuel pickup). We just installed another one yesterday. Never had any problems out of any of ours or ones that we have sold or installed. For the price you can't beat it IMO.
13,716
779
I have TTS dual pumps which are the same pumps Kennedy uses except without the fancy billet head. They come with a mounting bracket, hoses, quick connect fittings, controller, and all necessary connectors. The only thing you will need to install them is tools. I have had them on for more than 2 years and 30k miles without any problems. They push enough fuel for 700 hp and are extremely quiet.
9,903
149
I don't believe so on the LLY and newer trucks. IIRC, you use the vent tube fitting as the new fuel pick-up and the stock pick-up fitting as the return. The LB7 trucks require a fitting installed.
kenny
kennydiesel
Mar 5, 2009
319
washington state
Curious to know if the airdog 150 requires a new pickup tube or does it just lengthen the existing pickup tube? You have any install pics of the top of the tank or even the sending unit pulled showing the new installed piece? Thanks again for the help.:)
kenny
kennydiesel
Mar 5, 2009
319
washington state
You have any pics showing the details of this? Is that how you did yours? Thanks for the insight on this bro. Your help is greatly appreciated. Thanks again.:)
9,903
149
I believe on Kennedy Diesel's website there are step by step instructions on how to install their pick up but I believe all of the pick ups are done the same way.
othrgrl
Mar 10, 2008
2,151
Wilmington NC
IF you install the supplied 1/2" pick-up it requires you to drill or cut a hole in the top of the tank and use the supplied grommet and pick-up tube. If you cut the hole the right size the grommet is a very tight fit and we have never had a problem with any kind of leaking. I have installed them using the factory supply line as a return - rather than cutting the fill tube.
We have also installed them without the pick-up tube and made over 520hp on a stock LMM; so they don't require the new pick-up.
