What gear to pull in?
Frankin_truck
147
I am sure this has been talked about a few times but I will ask again. Does anyone pull in 1st gear high range? I am sure it's hard on the transfer case but the gearing from what I can figure would be just about right. I usually start in 2nd low range and get up to 4th low ranges. Any helpful info would be great
Dozerdog74
Lost Cause
Sep 13, 2012
101
Montgomery, IN
Im real curious as well, I am running very similar set up to you and I pull 4 lo, 3rd gear. I have 35's and 3.73 on gearing. I have had other issues to get straightened out, but should be all good now.
Frankin_truck
147
Yes it's my lmm, I am running a 305 55 20 3:73 gears. I have a pull coming up this weekend, I am going to try a 3rd gear start and shift into 4th but I really want to try 1st high range just don't want to wreck my t case or worse have a bad pull!
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I can't believe your hookin 4th. I was mid low 700's last year, and only pulled 4th on loose tracks. I also burned up alot of goerend and p.i. Torque converters
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
That's what I was thinking! Must be some really loose tracks or tires don't get much traction.
Does it snuff the turbo out at the end in 4th? Or keep digging?
I wouldn't know, all my last pulls lastyear broke lol. The one time I made it to the end I think it was gonna spin out but it snapped a u joint
L0B6Z
Oct 19, 2013
168
oxford ny
I pull 3rd low and I might go to 4th because I have alot of wheel speed and I think 4th might bring me down enough to get better traction. U can def smell burnt rubber at the end of a hard track. I run 373 gears and 285s. Rear pressure at 60 and front at 40.
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
Lol, u need to drop some serious air pressure... That would help!
Frankin_truck
147
I was spinning At the end of the track in 4th gear(low range). I will try and posts a video of the pull later after work
L0B6Z
Oct 19, 2013
168
oxford ny
I went with 60-40 because my tracks are usaully hard and I'm afraid if I go down to far I'll hop and not get a gd pull. I went from 65-50 to 60-40 this past weekend and never got below 300'. That's with no added wieghts. My furthest was 330. I don't run traction bars or bump stops currently, or wieghts.. That's 60 rear and 40 front
Frankin_truck
147
305/55-20 cooper st/maxx now, when I started this thread I was pulling with 305/65-17 bfg a/t might be better with the slightly bigger tire.
