Well it's been pretty cold here in michigan lately. For the past few weeks trans has been acting funny. It started. About 2 weeks ago when I left my house to go to work. 2-3 and 4-5 shifts will feel like there going into neutral between shifts. It did it for about a day or two the. Went away and was shifting perfect. Until yesterday it started to do it again and then would go away. I stopped by hsp to check the progress on my twin kit and when I left I put it into reverse and it felt kind of funny. Put it in drive and it was stuck in 3rd gear. Pulled into a parking lot and hooked up the scanner. I can't remember the code off the top of my head but I believe it had to do with solenoid b. I cleared the code. I put the truck in neutral and high idled it to help warm it up. Put it into gear and trans was fine. The 2-3 and 4-5 shift flare was back but went away by the time I got to work. Went to leave work and let it run for about 10 minutes. Put it in reverse and it was fine. Put it in drive and it also went into gear. Went to pull out and started driving. Put it In 4wd and went to take off and it felt like it was in neutral. Put it back in 2wd and it was stuck in 3rd gear. So I pulled off into a lot to check it out. Hooked up the scanner and had an incorrect 3rd gear ratio code. Shut the truck off and restarted. When putting it In reverse or drive truck felt like it would go into gear but would not move. Range shift inhibited kept popping up. Got under the truck and saw some fluid on the ground near the driver side coming from above the NSBU switch. It has never leaked until now. Checked fluid level and it was fine. After about a half hour I decided to play around with 4wd. Shifted into 4 lo and got the truck to finally move. Put it back in 2wd and limped it home.
Now here's the info on the trans. I built it about 2.5 years ago. Has a gmax 5 kit and MLG converter. Has around 30k on it and has shifted great until about 2 weeks ago when it got really cold. The trans was originally in my 03 and now is in my 05. Truck is stock with no programmer just has the built trans. Sorry for the long post. I just wanted to give as much info as possible. I'm going to dig into it more in the morning and see if I can pull some codes out of it.
