what does it ake to run pure alcohol
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Larger fuel pump & Fuel lines, Higher compression, and change any o-rings (carb) to viton. If it's carb'd you will need it gone through, to flow the meth. It's a pain in the ass!!! Every time you plan on having the vehicle down for a few day's, the fuel system needs to be either drained or purged with gas. Anything aluminum or zinc get's eaten if you don't. I did it for several years with the sprint car.
