The truck is 2wd, so what is in the sig what do yall think it will run? With about 1500ft, I am hoping for about mid 13's?
that will work maybe really good air 13.50s
yours looks like 4wd in the pic
high 13'sThe truck is 2wd, so what is in the sig what do yall think it will run? With about 1500ft, I am hoping for about mid 13's?
whats the point of racing it if you arent mashing the throttle? get slicks do it right id say or you may end up disappointed
Before i did the CP3 mod and injectors and EFILive, I ran a 15.30, idle launch, spun bad so i lifted, got back in it and limped the ally just past 1/8 and COASTED to a 15.30! If you can get some slicks you should do ok IMHO Oh and just H2O no meth in the tank!
Going to be running slicks. Hoping to get that mid 13, I wonder how much boost I can hold at the line with slicks? Just wonder why no meth, what if it is just 10% meth Peak wwf? Is water just better for racing?
Good call on the slicks, and good luck let us know how you do!
Ive gotten my truck into the high 13's before running 2wd no slicks, definently took some driving to do it. Barley spooling up and just easing into the throttle not to let the tires break loose to much. The hardest part is not mashing the throttle off the line
I think mid 13's would be doable, probably take practice more than anything, you will need a good tune also. Have you considered trac bars
