On this episode of WTF was I thinking the original plan was to just sound deaden the back of the cab turned into removing everything except the dash...
It surprisingly only took me an hour and a half to remove everything.
Once the carpet was out I vacuumed it up really good then hosed it down. While it soaked I mixed up some tide and vinegar. I kept it wet and scrubbed it with a firm bristle brush using the clean cocktail I put together. I rised it off each time after scrubbing. I ended up scrubbed it 3 times with a final good rinse making sure it was clean.
I then did what every good parent would do, hang it from my kids basketball hoop so they couldn't use it. You're welcome you ungrateful little shits!!!
Next the floor was vacuumed and wiped down with a mixture of dawn and Mr. Clean.
Plan is to use 3 sound deadening products.
1 - dynamat
2 - high density vinyl (1 LB/SF, 1/8" thick)
3 - closed cell foam (4mm thick)
I'm hoping this helps with my droning that's driving me crazy.
I have a resonator right off my down pipe that helped and want to try this before I get a 30" aeroturbine muffler/resonator installed after the torsion bar mount.
Yellowchevy
Sent from my Pixel 3a XL using Tapatalk
1 - dynamat
Yellowchevy
