What CP3 do you guys recomend?
TonOfDalt
More is better!!!!
Aug 9, 2012
153
42
Spoke Valley, WA.
I am in the process of building my 02 LB7 to be a better and more reliable performer. Think I am eventually going to build it to 400-450 HP and 700 lbs/ft. What CP3 would you guys recomend for this??? I need to replace the CP3 anyways as mine is weak and not buliding the pressure it should be so might as well get the right part for down the road.
I was thinking a stock LBZ pump would work?
3,727
296
Stock LBZ pump will do what you need, and then some. I made 425HP and 745 ft-lb at the wheels on a stock motor with the stock 285,000 mile CP3, and 1 failing injector. Just a tune, intake, and PPE boost increase valve. No smoke either!
So once you get your new CP3 and working injectors, you should be at your performance goal!
Sent from my Galaxy Nexus using Tapatalk 2
TonOfDalt
More is better!!!!
Aug 9, 2012
153
42
Spoke Valley, WA.
Thanks guys! :thumb:
I think I will start searching eBay for an LBZ pump for cheap... Anyone have one for sale? What air intake do you guys recomend? I plan on using the Air Dog II for a lift pump FYI.
TonOfDalt
More is better!!!!
Aug 9, 2012
153
42
Spoke Valley, WA.
Well, so far no luck on eBay. I am trying to excersise patience here for a great buy but I would like to have this thing so I can put it in the same time I get my PS injectors.
Noreaster
2,910
Cape Cod,MA
what have you done to your truck already? I see that its a handshaker
read the LB7 BPU thread http://www.duramaxdiesels.com/forum/showthread.php?t=9733
TonOfDalt
More is better!!!!
Aug 9, 2012
153
42
Spoke Valley, WA.
So far just EFI Live (20-20 Tune) Havent had a ton of time to play with it but I am very familiar with EFI as I have been tuning LS motors for about 6 years with it. Just ordered a LBZ pump... Supposed to be here Wed. (Mine was dying so I figured I would order for the future) Replaced DS injectors and have the PS on the way... Also arriving Wed. I think when I can afford it the first thing I am doing is an exhaust, and after that an intake... MORE AIR!!!
As far as Audio goes... I have a 6.5" Kenwood DVD Nav Unit I am putting in along with a JL 300/4 Amp/6.5" JL XR Components, and a JL 500/1 Amp/3 10" JL Subs in a custom box for under the rear seat. Should be pretty loud!
TonOfDalt
More is better!!!!
Aug 9, 2012
153
42
Spoke Valley, WA.
By the way... I just drove down to Florida and back... When I was almost there something went terribly wrong!!! I am pouring fuel into the crankcase... Like about 5-8 gallons per fill-up! Limped it home as I had no other choice. I think that the PS injectors fully bit the bullet since I replaced the DS and now there is probably more stress/pressure on the them. Didnt hurt the bearings (Tough ASS motor), changed the oil and pressure is tight where it should be with no loss in power. I do however now need to replace the rear seal. Tomorrow I am going to pull it apart in preperation for the new injectors and pump and see if maybe the return lines arent leaking too. 5-8 Gallons per 200 miles seems to be a ton for just bad injectors.
