What can be ?
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
try the easy stuff 1st pull the glow plugs and see if its hydro locked for some reason once the plugs are out try and roll the motor over with a socket and breaker bar to see if its free
Evan@InglewoodTrans
yerp
3,118
65
Western MA
I would bench test the starter and make sure the battery your using is in good shape then go from there.
on edit: I would onbolt it and see if it spins free first off.
PANCHORFO
59
took the starter and bench it, it's fine, the battery is fine too.
I don't know why the starter is refusing to spin, I measured the voltage of the wire that come from the ECM and is connected to the starter selenoid and it has 12v
http://www.youtube.com/watch?v=v-m41gPTvKQ
any duramax electronic guru ?
