Just wondering what guys are using for Manifold bolts for Pro Fabs. I have all of the factory bolts that are still in good shape. Should I just use those? Thanks for the input guys!
Can someone share what the OEM manifold bolt length is?
Just so you're aware, you can't use OEM bolts with aftermarket manifolds.
Correct. I am going from an aftermarket manifold back to stock.
Which bolt/stud do you want the length of?
All bolts are M10x1.5. There are 13 that are 61mm long. There is one on drivers side that is 36mm long. Then the 2 long ones, 101mm, 1 per side. Then the 4 studs. They are M10x1.5 at the cylibder head and M10x1.25 at the nut. 75mm long.Sorry for the delayed reply ikeG.
If possible I need all the lengths of the stock bolts as I am returning my manifold to stock and have thrown out the old hardware from when I upgraded my manifolds.
