went to the track again
redws6rocket
406
Odessa, MO
i got the 1057 and rebuilt allison done yesterday. best i could do is 13.08 @ 103. my hats off to kat for getting her truck in the 12's. i tried i just can't do it!
SmokeShow
6,818
Lawrenceburg, KY
Should have taken a leak or dropped a deuce. That would have been enough weight savings to get you there. :lol:
Still nice numbers.
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
Do you have a Co-pilot? It dropped .3 off Wendy.
Great times :rockon:
redws6rocket
406
Odessa, MO
Well then that would make you quicker :eek: The fuel alone would of put in in the 12's :p
are you taking any weight out of yours such as spare tire and others. you truck is very impressive. i need to try again with less weight maybe!!! also how are you launching yours, any tips!
BigWill_21
~BULL HURLEY Look-A-Like~
Aug 28, 2006
193
Greenville, NC
I am not sure about Kat, but I have removed my Spare and toolbox...
If you want to be 12.xx on the street then leave it all on the truck.
At the strip I remove tailgate as well, but the toolbox I use is a chest I can remove and the spare is always out, becuase I run 285's and the spare is useless without a jack to change it tot he frotn if a rear blows!!!
Post up your slip.. That way we cna see you 60' and times down the track.
What do you launch at RPM wise?? What kind fo Tires??? Etc..
BIG
Kat
Aug 2, 2006
17,899
13
60
Norco, CA
The only thing removed is the spare :D But I never have it on. I run with between 1/8th to 1/4 tank of fuel if I have my choice. Tailgate stays on.
Our tracks suck so I'm dropping my tire pressure to 32lbs all the way around and launching at 2100-2200 rpm's.
Kat
Aug 2, 2006
17,899
13
60
Norco, CA
Pull the spare, lose some fuel, and what ever other crap you have in your truck, that you don't need and you should be there.
Are you running in tow haul?
ripmf666
15,123
14
47
Wentzville Mo
always use t/h 1.892 60' 8.304 @ 83.62 1/8 12.998 @ 105.04 3/4 fuel no spare and tire pressure at 55 fronts and 50 rear also torsin bars turned up 6 driver side 5 pass side with 285/75/16 leaving at 6lbs
