Well this did not help boost of Egt's lol
ripmf666
15,123
14
47
Wentzville Mo
:eek::spit:
ripmf666
15,123
14
47
Wentzville Mo
X2 on that ! Didnt yours have a high pitch screaching sound? Mine did and thats how I found out:eek:
Yea it was screaching before fixed it and then it was just loosing boost and higher egts found alot of soot under the firewall lol and fuel filter was black.
ripmf666
15,123
14
47
Wentzville Mo
Henry you are suppose to un bolt the up pipe on removal not rip it out of the truck:eek:
She's good now has LB7 parts on her lol. It cracked the bellow in the were I could not get a pic. also I see you noticed it was tweaked just alittle also lol. Think it had alittle pressure on it.
ripmf666
15,123
14
47
Wentzville Mo
Can that just happen or is it because the bolts wern't tightened when installed?
I had one bolt that was out for a short time on the bottom til I got home to install it was I picked it up after the twin install. But they were tight the bellow has a fine crack running inside were it started to split aparts it also was leaking up were we caped of the riser for the erg cooler. I got 10psi of boost back and need to wash the firewall and valve cover and all down now.
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
Thanks I was just wondering. I seem ot have a problem keeping my up pipes from leaking. I also had a below leaking but a little weld fixed it up. More boost equals more problems. I can't wait.
