Well there goes my chances of 9s this year
Bbuchanan11
318
177
Sarver, PA
403C27B6-E59E-46B4-B383-5FAE9646ECF3.jpeg1DEC18C5-5D0B-4BE7-8CAC-A6B810DF3E9A.jpegWent to the track Saturday and didn’t end well… happened right at the top end trapped 133mph made for a very sketchy stop.. had mahle Motorsports cast pistons corrillo rods and Callie’s crank. Guess I have a winter project now.
  • Wow
Reactions: Silver06
Bbuchanan11
318
177
Sarver, PA
I’m guessing a piston the wrist pin was laying on the skid plate with a bunch of chunks of aluminum broke both sides of the upper oil pan. I didn’t get to see any of the parts laying on the track.
Bbuchanan11
318
177
Sarver, PA
Started pulling the engine couldn’t turn it over the whole way to get the converter bolts so I was able to reach my hand in the hole and pulled this out
  • Sad
Reactions: malibu795
Bbuchanan11
318
177
Sarver, PA
There is just about nothing left of the rod other then the cap and about an inch of the beam if that… I wouldn’t ever think I made enough power to break a corrillo rod.
Bbuchanan11
318
177
Sarver, PA
So I happened to come across a free lbz block but it has already been bored 40 over and it looks like it sat for a long time.. I guessing it would need bored again. Is it worth/safe going any bigger or should I just junk it and find another one?
4,165
1,274
I personally wouldn't go any larger, these cylinder walls are thin enough as it is. That's just my opinion tho.
Bbuchanan11
318
177
Sarver, PA
Pulled the injectors today the one on the right was in the hole that let go.. I had blow by all over the valve cover o ring was gone and the end was loose if you look close you can see the body is swelled on it.
