Welding turbo coolant line
Porno Joe
513
South of Pittsburgh
With the factory turbo gone I have been running a simple loop between the two lines that used to feed the turbo.
I keep getting small seeping leaks and want to get rid of this hose. I've got the plug for the upper rad hose.
My question is for the other end- I believe this metal line goes down under the thermostats and connects to the black pipe- is this correct?
Also is it possible to remove this without tearing too much apart? I have a spare one I was going to weld up and swap in
