Weird Turbo oil leak
68skylark455
Larry the "Stroker"
Aug 7, 2008
1,091
Texas
www.larrysperformancepalace.com
Anybody using a GT4202r Turbo kit? I have an oil leak coming from around the drain pipe on the bottom of the turbo-it was leaking there before I built this engine, I replaced the gaskets and its leaking again-only when you shut off the truck?wtf? It kinda looks like it may even be coming out from the exhaust side of the turbo housing by the v-band clamp. Any ideas-there was no oil inside the turbo housing when I had it off. Just wondering if anyone else had this happen? The guy I talk to at PPE where we bought the kit is out till monday.
paint94979
Beer Nazi
Sep 18, 2006
11,715
Talk to Dan@PPE
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
Mine leaks at the oil drain tube also, I have replaced my gasket twice now and it still leaks. It is just so damn hard to get those bolts really tight enough to crush the gasket!!! I am going to make a tool to get in there better. I believe an old distibutor wrench will work, i think I heard that from Pat.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
its not the gaskets. ive done a few of thes and its the tube where they weld the collar onto it to make it longer to accomodate bigger turbos. Had to braze mine.
vortecfcar
No longer a member
Jun 28, 2007
167
I use a pivoting head ratchet wrench and I tighten them before I bolt the turbo to the pedestal. It's the first part of the turbo that I secure to the truck.
I've reused gaskets several times without leaks.
Might help somebody..
Nick
delle_54
Mar 1, 2010
I know this is an old thread but curious as to any other fixes. I have the same issue and looking for as much info or different possible repairs.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
On gaskets that are a pain to get to, or get the bolts tight, I use a spray contact cement on both sides to help hold the gasket in place & help it seal.
Something else to consider is the GT4202R needs to have the oil supply restricted, per Garrett.
Cat also has some new turbo gaskets that are metal with a rubber seal. I can't remember the part number off hand.
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
Part # please:D
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
I torque each side down little by little and haven't had a problem. Those gaskets do sound nice though Albert.
