Weird allison issue
Bigred22556
May 16, 2018
5
So I'm having an issue and it has happened with two transmissions now at random times my transmission will puke all its fluid out fill it back up and it will be fine no leaks for weeks then it dumps all the fluid again I'm at a loss as to what it'll be
15,681
Have someone qualified check it. We have no idea without seeing the truck.
Bigred22556
May 16, 2018
5
No temp spikes at all and that's the problem I'm a trans tech and it has me dumbfounded two transmissions same issue new Tcm same issue I'm lost
2,146
Same or new converter? What is the fluid level on the dip stick while warm prior to it puking?
Is the fluid clean and clear when it comes out or is it milky or strawberry shake colored?
Bigred22556
May 16, 2018
5
The fluid is clean new converter on both transmissions and it is at proper levels for the temperature it doesn't matter if the trans is hot or cold when it pukes fluid it has done it cold at start up and hot on shut down and the cooler was flushed both times
15,681
Possible a front seal on the transfer case leaking into the trans. Check fluid in the TC.
Bigred22556
May 16, 2018
5
I figured it out the tcm was bad (go figure) it was calling randomly for extremely high line pressure higher than what the trans was designed for and it was popping the relief valve and blowing the fluid out of the vent and screwed the seals up in two brand new ati transmissions
15,681
TCM can not do that.
