Wehrli 100337 4" Intake Kit, looks nice with the powder coating color of your choice, but i have always went with S&B or Banks in the past .
Any insight?
Any insight?
HSP and Wherli intakes are trash. Yea they look nice. They just suck hot air from the fan.
Do you have any data to back that up?
Reason I ask is I have a open air intake from a WCfab compound kit, The intake temp is only 10-20* warmer than ambient temps. and that filter sets right the path of fan wash.
On another unrelated note the stock intercooler works very well as the y bridge carries temps 10-15* different than intake charge air.
In a NA application your right, but for us it all depends on how efficient your intercooler is. With my open filter, my IAT readings is within 10-20 degrees of ambient whenever I am driving, if it was 50+ degrees more I would start getting concerned. Unless your have a Air to Water intercooler with a ice box, your charge air will never see better then ambient air temp, so as long as your close to ambient, don't really sweet it.HSP and Wherli intakes are trash. Yea they look nice. They just suck hot air from the fan.
Here are some images of my under hood when I stopped for fuel when towing 10K on a 90ish degree day.
Edit the max my Thermal sensor will read is 302, so temps can be much higher.
On a 100* day let it sit and idle then measure your temps.
Just like the LLY where one of the fixes of over heating is to install an LBZ mouth piece and intake that’s sealed to the fender where it doesn’t get hot air from the fan.
i understand it is just air flow, but you never know with all the aftermarket stuff out there sometimes there is just odd issues with simple parts.
Can you share yours? At idle on a 100 degree day your IAT might stay at 100 but what is your charge air temp? As I said before, your intercooler has to be efficient or it will heat soak due to lack of airflow and your temp will go up irregardless of your IAT.On a 100* day let it sit and idle then measure your temps.
What one of the two is the bigger contributor to the fix? I installed a intake horn on a LLY after a S&B intake was installed for a while and the owner said there was no noticeable change with the intake, but a when the intake horn went on, he said that it was noticeable. Granted this was with general performance, he wasn't having any overheating issues.Just like the LLY where one of the fixes of over heating is to install an LBZ mouth piece and intake that’s sealed to the fender where it doesn’t get hot air from the fan.
I really don't see how idling the truck and it heat soaking makes one bit of difference, also why are you idling the truck for long on a 100* day makes no sense. short of it is it is no affected as much as you think.
Also that's not why the lly had over heating issues, the issue was that the mouthpiece was inefficient and caused high EGT due to lack of air flow not temp.
Idling the truck makes no sense as it is not under load. Sure it pulls hot air in at idle as it has nowhere to go. Under normal conditions driving I see 10-15F hotter than ambient with my S&B.
Look at most guys making big power..... No airbox at all.
I mean idling the truck on a hot day and trying to spool the turbo, let’s say at like the track .
I really don't understand this thought process either. turn off the truck if you are waiting, on top of that I really don't thing you will see much power loss over what you are seeing I bet it would be hard to see on a dyno as well..
I’m the guy that has an open intake and let’s my truck idle hours on end on hot days, when you first get going it is laggy and smokes worse, but IMO, if you’re idling on a hot day, I don’t care what I take you have it’s going to get heat soaked.
