We got bored today!
NWTDIESEL, myself, and one other friend were bored so this is what we did today. What do you guys think? Plan on doing intercooler piping later on.
beach_33
704
des moines, IA
this is what i am talking aboutQuote:
Originally Posted by Killerbee
There are no commercial aftermarket intakes that fix the LLY compressor efficiency issue.
I thought PPE sold one? What do you suggest?
larger image Add to Cart:
2004.5 - 2005 Intake Manifold Kit for LLY
Model: FGRCMANILLY
$489.99
Product Use Disclaimer:
These components have been designed and are intended for competition and off road use only. It becomes the sole responsibility of the Customer to ensure that the use of their vehicle and items purchased comply with federal, state, and local regulations. Performance products are legal in California only for racing vehicles, which may never be used on a public highway. Customer assumes all risks and expenses relating to unlawful vehicle operation on public roads. PPE shall not be held liable for unlawful vehicle operation.
Application: 2004.5 - 2005 LLY 6.6L Duramax diesel engines
Features:
High Performance Intake Manifold tub allows more oxygen intake for more complete combustion and more power that increases inter cooler efficiency
Simple to install
Killerbee
Got Honey?
Mine is metal, what do you mean fix the elbow inlet? I have the elbow that came with my turbo. The stock one is long gone.
the wrapping looks good.
You need to remedy the big ass restriction just downstream of the AFE tube. Take off that "mouthpiece" and look at it. You'll see what i mean. It's not that hard to remove.
Consider that at full throttle, 800 cfm of air moves through your insulated tube at 100 mph. Through conduction, convection and radiation combined, how much heat do you think it can pick up in that 0.02 seconds it takes to go from the airbox to the turbo? FFT.:)
beach_33,
I haven't fixed the "LLY compressor efficiency issue" yet if that's what your're refering too.
Killerbee,
Where can I find a pic or somethin' because I don't get what you mean by "mouthpiece" :eek:... and just to clarify I have the LLY with the aFe and NWTDIESEL has the LB7 with a MAC tube and aftermarket elbow. We weren't sure who you were were talking to :confused:. I know for a fact NWTDIESEL has no restrictions. ;)
The stock VGT, and the Cheetah will both gain 10-15% MAF from the IOH Kit. Also will gain 4-8 psi of boost performance, while running lower shaft RPM.
It replaces the stock LLY mouthpiece with a modified, larger mouthpiece.
There are economy gains as well, 1 mpg minimum so far.
Thanks! That's alot of good info. I'm going to look into it further but the hand machined LLY mouthpiece looks like a good fix. Thanks again for the help.
