LBZ: Water pump
Eddie_LLY
Colorado
Does switching harmonic balancers away from stock affect the balance of the rotating assembly?
I thought this was only a built motor thing?
3,727
296
We put one on a stock motor after we spun the stock balancer. It never ran so smooth.
I don't see any problem with using one on a stock motor, and if you've got a decent tune, it is good insurance against spinning the balancer.
Sent from my FlashScan V2
Blackmax123
683
central Pennsylvania
It wouldn't hurt to replace the seal, especially if it's high milage. But the socal or ATI damper use the same seal as stock. But I'd say if you have the seal driver I'd replace while your at it.
Sent from my SM-G935V using Tapatalk
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
The truck has 75,000 miles and has a mild EFI 90HP tune, I'm sure a lot you guys are sensitive to vibration and the Duramax engine has an ever so slight vibration right at about 1800 to 2000 RPM that I have noticed since 2013. I have read a number of post' where an ATI/Socal damper smooths out a stock engine...What about adding pins using EDP's? crank pin installer.?
Concerning the seal, it looks like the seal driver J-44645 is to be used with the front cover off or is there one that can be used while the cover is on the engine.?
http://www.ebay.com/itm/AUTHENTIC-K...al-Installer-6-6L-Diesel-2500HD-/361872183185
Blackmax123
683
I used the seal drivers from merchant automotive when I built my engine. Installed the seal with the cover on. If that seal driver is deep enough looks like you could use the face bearing and bolt (if right treads) to drive the seal in with the cover on.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Thanks Blackmax, and add an additional pin with this...:thumb:
http://www.duramaxdiesels.com/forum/showthread.php?t=56947
DangerousDuramax
Nov 3, 2006
124
Houston, Tx
Man I feel your dilemma with only having 75K on the clock but my mind tells me that when I've got something tore down that far its always good to replace a cheap expendable part just for safe guard. Do you NEED to change it...no...but you'll kick yourself in the ass if it starts leaking in 20K and could have replaced it easily when you had the chance.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Thanks, not sure what it is as I have been chasing this noise for about a year with no leak or overheating. I have read that water pumps can make strange noises being a gear driven pump.
I'll just have to keep that in the in mind. I have replaced the idler pulleys and tensioner pulley plus the AC clutch bearing might be making noise.
I "sighted" the balancer the other day while it was running to see if it was wobbling and it is spinning true..
skintback
Take this one to church
Mar 5, 2007
919
Florida
I have seen the cheap water pumps make a very odd noise so be careful of what you go back with I have had good luck with AC Delco and GM pumps. With only 75k on the front seal and not have the correct tools to pull it and install it i would not mess with it at all The front and rear seals on a duramax seem to be pretty tough and go the distance.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
This X2^^^^^^
Blackmax123
683
I don't know about rear main seals being tough. I've seen my fair share of rear main seals seeping oil. My 13 lml is included.
skintback
Mar 5, 2007
919
Florida
Most the time what you think is the rear seal leaking/weeping is the upper oil pan/rear cover meet at least from what i have seen
Blackmax123
683
I have seen some seeping there, it's kinda a poor design where the rear cover and front cover meet the oil pan. But the ones I'm seeing are dripping out the little hole between the rear engine adapter and the bellhousing.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
OK, Danville pinned or stock configuration left alone. I have read about few welded pumps failing and being how forums is where the bad apples end up and I'm bound to read that, all the bad shit ends up on forums with a little good stuff sprinkled in...
Maybe I'll get lucky and Oreillys carries ACDelco or equal, the idlers and tensioner I purchased from them were Gates made in Canada and you could not tell the difference between them and the originals I removed.
The Kent Moore Front Crankshaft Seal Remover Set J-44644 seal remover is pricey
http://www.mytoolsforyou.com/automotive-tools/OTC-J-44644.html
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Pinned pump, if the seal aint leakin, don't replace it. ive done a lot of water pump jobs and never replaced the front main, with 4x the mileage. I wouldn't go with a fluid damper as its heavier than stock and we already have crank issues, but that is another topic.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
I agree on going with a pinned water pump. Nice bit of insurance.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Just gonna drive it and keep an eye on it, I read about the Fluid Damper being heavy and coupled with Duramax crank issues I have to agree and ATI/SoCal is what I'm considering
Thanks...
