so i replaced the pump this weekend and it was a bitch... now my radiator is leaking from a spot in the fins towards driver side bottom!!!!!!!!!!! can it be patched?
Shouldn't have been too bad. Drain the radiator, remove the fan and shroud, remove the harmonic balancer, disconnect the lower radiator hose from the pump, 7 nuts and bots gets the pump out, 4 more get the pump out of the housing, then repeat in reverse. With electric fans and a SoCal balancer mine was even easier a couple weeks ago.
A radiator shop should be able to fix the radiator. Some braze it and others use and epoxy. Unfortunately, they often want you to remove the radiator.
