Water meth
jpowel29
780
Bentonville, Arkansas
I ran two meth nozzles in my intake off a Hobbs switch set around 15psi. I was probably running 70% M1 meth and distalled water. Boost would climb nicely on the line once the meth activated. Not like nitrous but it does help create some added exhaust volume/velocity. No clue on EGT or IAT reduction - wasn't data logging that when it was running. Normal driving I would run through a 4gal tank of water/meth pretty quick so that is why I kept the boost activation set at a higher psi.
