Water intrusion
Cougar281
1,803
249
St Louis, MO
I've been having water get in on the drivers side, soaking the carpet, but I haven't been able to find anything to point to a general location that the water is getting in, until today. I found it running down the side of the parking brake and dripping from there.
Does anyone have any thoughts as to where it could be entering, before I unnecessarily tare apart half the truck?
2,073
Can you cause it to leak with a garden hose around the exterior? I'm thinking either windshield sealant or cowl
Cougar281
1,803
249
St Louis, MO
Haven't tried it.... Going to have to wait for the weather to dry out to try. Is factory windshield sealant letting go or leaking eventually a common issue? My Cougar has had a leak in the back for years that would cause the trunk to fill up with water (It lives inside now), and I suspected the rear window, but an auto glass guy told me that typically, undisturbed factory sealant doesn't 'just fail'.
Cougar281
1,803
249
St Louis, MO
So I just went out to take another look, and I noticed a drop hanging off the bottom of my guage pillar...
I also noticed for the first time that the corner of the headliner at the A pillar is damp, suggesting the marker light and/or onstar antenna as possible culprits...
2,073
That would be my next guess. Either the antenna or roof marker lights. My Jetta had a leak at the antenna. A loosened it up, put some polyurethane sealant under it and tightened it back up and hasn't leaked since. Going through the headliner was a pain
DuramaxRamRod
139
11
NH
My dad's '03 had rust on the cab and was pushing out the windshield but it was pretty obvious with water coming down the inside of the windshield.
Ron Nielson
736
131
Berryton, KS
My method is to use painters tape and cover as much of the suspected area as you think might stop the leak. Then apply water and see if the leak stops. If still leaking, increase the coverage area; if the leak stops, remove some of the tape, say 25%, and see if it begins again. If it leaks, find the leak precisely in that 25% removed area. If it doesn't leak with 25% removed, remove more tape and test again.
Cougar281
1,803
249
St Louis, MO
Ugh. Found I have leaks everywhere lol. Pulled a bungee cord out from under the flap behind the rear seat and it was wet. Found the cab vent seals are cracked and leaking.
Edit: will the newer GMT900 LED cab lights fit on a GMT800, or is the roof profile too different?
Reactions: 2004LB7
994
Seen a few people do it . maybe put silicone underneath to seal it?
Cougar281
1,803
249
St Louis, MO
That was pretty much why I was asking... It seems putting silicone under leaking clearance lights resolves the leaking, but it would also make removing them 'more fun' when a bulb goes out, so if I could replace them with newer LED units and silicone them, it's 'less likely' I'd have to remove/replace one down the road.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,448
447
Central OH
If you look at how the cab is molded together at the roof, water can come in at the 3rd brake light and take multiple different paths depending on how the truck is sitting. That would be my first guess
Nate’s Dmax
188
Yes if the truck came from factory with the cab lights the newer style will not work very well. I would get a new LED set for the model year and caulk them a little on install.
