Wastegate question
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
What are the specs on the s472's?
I would think one big gate around the primary s472. Couldn't imagine needing a gate to go around the atmo s472's if they are setup correctly.
CaptPhil
1,012
Delaware
Thats good to know. The current gate setup on white devil is a single 45mm around all the turbos, i was thinking that I would need two gates, one around the 472 and one around the 366's, but now I might just try gating around the 72.
Good info.
S Phinney
4,008
Quncy, Fl
I run a 60mm around my 72. You can do anything you need with that. No need to complicate things more than necessary. Gates still need adjusting for the system that it is used in to get the benefit if one.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Good info.
Sounds like an odd setup. One gate bypassing all 3 turbos?
delong_1
<< my work
Dec 5, 2008
1,282
Arvada, CO
to be safe id run one 46 to bypass the high pressure and feed the atmo's and another to dump to the exhaust when nitrous is used. this is how i have done them on all the stuff running spray.
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
Triple 472s and nitrous should make for an exciting combo. Curious to see what comes out of this.
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
I run a 44mm around the High psi S475, nothing for the low psi 475's. Last season I ran no gate, killed the GT 42/45 but never killed the 475 un gated. Up pipes last longer now that it's gated though ;)
BSdiesel472
Smoke
Feb 24, 2015
47
Southern Pennsylvania
I dont know I'm kinda leaning more towards a slightly larger high pressure now I think. Been putting off buying the third 472 cause I can't make up my mind. Wanna stay s400 though I think
