Warning: NAPA Brake Clean
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
I bought a case of this brand (CRC), and out of the case, so far 4 cans have failed. The valve leaks when you first use it, and it leaks until it's empty, takes 1 to 8 hours to empty a full can.
I will write NAPA monday.
05chevy
1,086
I use napa brand 4810 and have no problem with it and use about 4 cases a week
WanaDmaxsub
Junior Member W/gray hair
Feb 17, 2007
644
Grab an empty (finger pump) spray bottle. Spray the cleaner from the leaking can into it. It only takes about 2 mins to empty a can holding the valve down.
bluebowtie
duramax addict
Jan 1, 2011
62
Madison WI
Pull the nozzle up it should stop the leaking issue. We have had this issue with cans of spray silicone at work.
Sent from my iPhone using Tapatalk while drinking a spotted cow
messejme
Jazzy, Me and Max
Mar 7, 2008
741
Branchburg NJ
sounds like the molded spray button is not being made to prior specifications. I would guess and say they are now using a foreign made part and the quality just went down the tubes. If this is the case, Shame on CRC.
