VGT solenoid pigtail connector
13,709
770
I'm having trouble finding one of these other than from the aftermarket, and I've had too much bad luck with aftermarket connectors. Does anyone know of a quality connector for the VGT solenoid? I tried GM, and you have to buy an engine harness to get one. Thanks.
02greysixer
1,829
North Central FL
Try ford. It is the same connector as a 6.0 powerstroke vgt actuator. Pretty sure ford offers it separately.
Sent from my SM-G930P using Tapatalk
13,709
770
I already tried because I actually need it for a Ford, but they only sell the version with the little plastic tabs on the side. I want the same style the Duramax uses with the steel wire. The plastic tabs always seem to break off when you try to remove them; I guess the heat from the turbine housing makes the plastic brittle.
02greysixer
1,829
North Central FL
Yeah they don't last. I keep some old 7.3L injector pigtails cut from valve cover gaskets to use in a pinch. They have the metal clip but no rubber seal.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
This ^^ works well
Blackmax123
683
central Pennsylvania
Josh, I believe the ipr valve on a 6.0 has the same plug but with the wire clip. Might wanna see if Ford has that one available. The 6.7 also uses the same vgt plug but they're plastic and always break as said earlier.
13,709
770
I tried that. They list the same part number for that connector as the VGT solenoid pigtail which is plastic.
