Okay so these symptoms are not of my truck, but of a friends. We have tested everything as far as electronic tuning goes, turned stuff off that is rarely messed with from tuners just to see if it would change anything and nothing... Been through several Tcm tunes, no luck.
Trucks info:
Lbz 6 speed Alison built by Trent Nell, Unknown what his kit consisted of, standard ml converter with an adjusted stall (so we think). Engine is a built motor, the daily driver tune should be around 750 hp which is what we are testing it on.
Symptoms:
Since the build it's been doing this like crazy, and it has trouble locking the torque converter. Normally It won't lock till 4th gear. We have always thought the problem was just it was lacking a lockup controller, and now we installed one and it made the defueling more noticeable on the shifts. It's not your average defueling, it falls flat on its face then picks itself back up again when it gets in gear.
There was a trans with similar symptoms in the past (hondarider552) but his was only on the 2-3 shift. He had a blown valve seal on the c4. So my question is can a different valve seal blow that will affect all of the shifts? The c1 is what I have heard but just want to get some insight before we tear down a transmission... Are there any other ideas that come to mind to try? We are going to swap his and my Tcm tomorrow and see where it goes from there.
Thanks in advance,
Caden
Trucks info:
Symptoms:
Thanks in advance,
Caden
