What is curious, is that when I flashed Casper with TIS2000, everything was replaced except the O/S. None of the old files were kept; all were new. Look at the Calibration ID's, none match the original Calibration ID's that were on the truck when it was sold.
Of course all these "new" calibrations will show up on the CVN checker, but how could they be different? Unless GM got the CVN's wrong on their website.
WOW!!!
Look at the first CVN's I posted. This was a 10 second Race Only Big Charger Dual Fueler tune.
It has the same CVN as the stock tune!!! Exactly!
That is what I have been saying all along. The CVN doesn't know the file the file has been modified.
But why does GM have the wrong CVN's on their TIS website?
WOW!!!
Ok so how do we get this changed, or straightend out.
Is this a viable court case or is it just another way for GM to stick it to the people????
Pat,Guess what kids?
GM is lying.
If the dealer reflashes your truck with a Tech2, it won't match either.
So all that CVN proves is that SOMETHING might have reflashed the truck, even a Tech2 with Factory GM Calibrations.
This is truly bizarre.
But EFILive's CVN's matches what a Tech2 CVN is. EFILive doesn't change it.
Pat,
Did ALL the CVN's change after you reflashed it, like they did on Tired Old Man's truck?
If the CVN truly is a checksum of the file, I can't see how it can change if the file is identical, unless the ECM increments something in the file while it's being re-flashed with the same cal's, in which case all this would tell you is that the ECM has been reflashed.
I sure would like to see what you would find if you were to compare the files using a byte comparison utility.
Tired Old Man - Did you buy the truck new?
If this were my truck, I would want to go back to the selling dealer and try to find out if the coach builder made any changes to those files before the truck was sold. It's worth the price of a new engine to find out the truth.
