Valve question
LtEng5
74
CT
yup. same size...
be care full using used springs...... check the pressures at seat and open at recommended install heights and open heights based off came lobe and rocker ratio...
brokesmoker
141
Virginia
thanks guys I have a set of lb7 heads with so cal valves and springs never been used but ill take them to machine shop n let them check the seats and replace if necessary, thanks for the replys
