Wanted to get some info from you guys. Looks like my 05 lly threw a rod or broke the crank. All started with an injector issue and then low oil pressure. Now it won't start but I was told no compression. What would be the value of this truck? I don't have time to part it out. 2005 lly 2wd extra cab. 220,000 miles. Everything worked on it but it was the basic model with crank windows and vinyl seats. Body is ok but the bed is a little rough. Dsp 5 efi live by Ppei. 3" downpipe and brand new mbrp 5" exhaust, sinister egr delete with lbz mouthpiece. Transmission is good and so is rear end. Only issue is the engine. I just changed both trans filters and fluid a month before it took a dump. Thanks for the help
