Anyone know who sells just the cable that goes between the V2 and the obd2 port? Mine won't stay in the V2 on its own anymore.
Thanks. Was trying to avoid buying from efilive direct. Didn't think anyone would stock the cables themselves as nobody lists just the cables on their sites.
If you know any IT guys they can install a new end on it fairly easy.
Used to but not anymore.If you know any IT guys they can install a new end on it fairly easy.
Duh that's a great point. I have those ends and the tools too.
Pretty hard to f it up if you have the old one in your hand.As long they get the pinouts on the OBD-II port side terminated at the correct spots on the RJ-45 connector, too bad the cables are not 8 ft instead of 6 foot...
If you say so.OK, seeing the wire colors and the striping can be difficult at best...:thumb:
Just following your lead.
Not sure why you think it would be tough to see the wires or colours. They aren't that small. Plus anyone doing this kind of job would also have at the very least a magnifying glass if not a bench mounted lit one.
I'd do it myself but don't feel like buying the tool.
