V2 balance rates
Bonestock
1,358
Worland Wy
Hello all I know this had been talked about before so I just thought I would check with everyone first. My question is on EFI live v2 balance rates I have 2 cylinders that are bad. According to the v2 cylinder 4 is 6.98 & cylinder 1 is 4.95. Do the balance rates on the v2 correlate to the correct cylinders?:(
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Hook up your laptop and check them first. I had one the other day that kept saying I had 2 at 15, but when I hooked it up and used it in pass through they were all +/- 5. It still ended up having bad injectors, but the V2 doesn't read even CLOSE to what it does with the laptop I have found.
Bonestock
1,358
Worland Wy
Efi
I should have been more clear on the v2/ laptop. I did have the laptop connected just wanted to verify cylinder correspondence. I remember awhile back somebody was using dvt tool shutting injectors off & when they shut off say cylinder 8 they found their problem but cylinder 8 wasn't cylinder 8. Thx for all the replies.
