v1 vs v2
03 D-max
Honorary "Tosser"
Apr 29, 2008
3,539
Lowville NY
i searched for quite a while and never found what i was looking for so with that said... what are the main differences between efi live v1 and v2 i have been looking at buying efi and v1 is alot cheaper i want to be able to tune my truck and buddies trucks:D
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
V1 cannot tune LBZ's or LMM's. So if your buddy has one of those a V1 will not work.
Kat
Aug 2, 2006
17,899
13
60
Norco, CA
nope lb7's and one lly :D so is there any other big differences?
I will defer that question since I'm not the tuner of the family :eek: I know V1's require a license for each ECM and TCM where as the V2 1 license will do both ECM and TCM.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
As far as actually tuning NO just can do lbz+ So if you ever plan on one I would get V2.
In the futre V2 will use a SD card to store tune,So you wont need to carry a laptop with you
V2 you can use to clear codes with out hooking up the laptop also
In the END V1 will:grd:
Jared Duramax
<---- $$$ Whore!!
Feb 13, 2008
1,052
Matthews NC
i would personally get the V2 because one day we will be able to flash with out the laptop and we can now scan with out it also. plus there are alot of cool features with V2 such as the code reader
LBZrcks
Jun 2, 2007
5,297
12
SoCal
GMPX said:
Updates / Features list:
Added tuning and scanning support for many new 2008/2009 E38, E67, T42 and T43 operating systems (click here for vehicle list). This also includes support for a number of Hybrid vehicles using the E67.
Added option to manually enter your own calibration verification numbers (CVN) for E40, E38, E67, T42 and T43 controllers (LBZ/LMM not supported). Workshops can now uniquely identify their own calibrations. This feature is only available to customers with a stream license for the target controller(s), those without a stream license cannot correct CVN's, this is done to help prevent fraudulent manufacturer warranty claims yet still allow workshops to quickly identfy if a tune has been altered. It is available via the new [CVN] tab page on the calibration details window in the EFILive Tuning Tool software.
Updated E38 & E67 bootloaders to stop the intermittent false 'flash failed' error at the end of a full reflash on 08+ vehicles.
Released the updated DSP5 LB7/LLY Diesel operating systems which allow tune switching from the V2 hardware or via a hardwire switch.
FlashScan V1 Workshop cables and FlashScan V2 cables with matching stream licenses can now transparently re-flash controllers with missing serial numbers.
Changed the following PIDs to use PSI instead of inHg:
- GM.EGRVAC
- GM.BARO
- GM.MANVAC
-GM.MAPBOOST_DMA
Script generation has been changed so that if an entire table is to be added to the script the coordinates are generated as “.” Instead of literal min/max column/row values. That prevents scripts failing when run against tunes with different axis labels.
A command line parameter of – (a single minus sign) will cause EFILive Tune Tool software to not attempt to load any pre-existing *.tun files. To use this option, you need to create a shortcut to the EFILive Tuning Tool software with a target of: EFIlive_Tune.exe –. (I.e. EFILive_Tune.exe<space><minus sign>)
Launch control spark retard PIDs added for Lingenfelter LNC-002 launch controller. PIDs are called:
- CALC.LNC002_1
- CALC.LNC002_2
Added F.A.S.T. wide band O2 analog PIDs. PIDs are called:
- CALC.AFR_F1
- CALC.BEN_F1
- CALC.AFR_F2
- CALC.BEN_F2
- CALC.BEN_F1_B
- CALC.BEN_F2_B
- CALC.BEN_F1_E38
- CALC.BEN_F2_E38
Added two new SAE PIDs called:
- SAE.FUELTYPE: Fuel type
- SAE.E85R: Ethanol Fuel Percentage
I think that day has already come, atleast for the LB7/LLY guys;)
