Using biodiesel as lubricity additive
2005DMaxCCSB
Sep 17, 2010
12
I went by Down to Earth Energy in Monroe GA yesterday, and got 5 gallons of B100 and they gave me a quick tour of the plant. Most impressive and one heck of an operation. They have B100, B20, and B20 for offroad.
I got 5 gallons, as I am looking for an alternative to my beloved Opti-Lube, and I have found it!!
I added about a quart to 2 to my 3/4 full tank.
When I started it up this morning I was in shock at how quiet it was!!
Usually it takes a minute or two before it quiets down, but not with biodiesel.
I thought the Opti-Lube made it sound like a sewing machine in an oil bath, but compared to the biodiesel, whoa!
I will be using the 5 gallons as an additive and whenever I am in the area filling up on B20.
Bad picture, and from the back of the plant, but if you are in Georgia, give them a shot, I think you will be amazed at the difference it makes!
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
What do they filter it down to?
I'm not going to use bio again. About fubard my injectors and fuel system.
I'll stick to power service :thumb:
2005DMaxCCSB
Sep 17, 2010
12
2 micron, and I have an airdog2 that is also 2 micron
I figure using it as a lubricity additive is economical, and so far the results have been stellar.
What do you mean "About fubard my injectors and fuel system"?
Opti-Lube tested far better than Power Service, just fyi, it was #2 and biodiesel was #1 :thumb:
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Had what looked to be "shit" and water in the bottom of my fuel filters, and clogged both my 1 micron and 2 micron filters. Wouldnt go above 2800rpm.
D-MAX Mafia
Hood down, smoke up!
Nov 4, 2009
1,112
13
Phoenix
Looks like the filters did their job! Also if you know anything about bio-diesel, it will act as a solvent and clean the entire fuel system as it travels through it. Most places require that you change the filters after a short time of running b-d because they will become clogged with the junk in the fuel system. Just like yours did. Doesn't mean the fuel was bad it just means you had a very dirty fuel system.
I run cheap trans fluid in my truck. Helps keep everything clean and oiled up. Just met a guy that lives about 5 miles from me and he makes his own b-d. Probably gonna switch over to that since its only 1.50 a gallon and he does all the work.
03 D-max
Honorary "Tosser"
Apr 29, 2008
3,539
Lowville NY
I ran 100% bio for a summer, only problem was if it got down to 40 degrees the stuff would gel up, other than that it ran great!
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
The problem was that I was running b100 for more than 6 months prior and its not my first time running it, so I know I got shit fuel.
