I've never used this before. Always used EFILive to tune the LB7's and LLY's. But I'll be leaving my LMM tuning to Tony. He suggested going the Autocal route. What is everyone's experience?
Nick
Nick
The only thing that kepted me from getting one, was the fact that only his tunes will work one it. If you ever want to try someone else's tunes you will have to get another one.
true but something tells me that Tony can handle what he will need...
Auto cals can be UNLINKED from the original tuner so they can load another tuners tunes on the and try them if the customer wants.
I just purchased an autocal from Tony. A friend said to me "You know you won't be able to modify the tune" I said yes, but why would I pay Tony to tune my truck if I'm going to modify it anyways?
Yes , true...
But then again, Tony can modify the tune when and if need be:thumb:
The only downsides to the auto-cal is: personally not being able to adjust anything
That is very true, however if it is unlinked from one tuner and relinked to another then the tunes from the unlinked V2 cannot be loaded until it is relinked.
I just had a long conversation with a customer on Friday regarding this issue, he wanted to play around with his own tunes and a friend of his was going to help him, I told him I would gladly unlink the Autocal but if his buddies tunes didn't work out he would no longer be able to load the tunes I sent him.
He didn't quite understand why at first, but keep in mind that yes you can unlink them and relink them but the unlinked tunes cannot be loaded again.
Your right, but doesnt the auto cal relink with you if he uses the tunes you sent him again? I'm sure I read that in the PDF for tuners for autocals?? but maybe not.
