Finally showed up along with my wastegate. The pics are someone else's of the same pedestal.
Lets see the wastegate....
Exciting huh? Good choice btw
Does it come with a block off flange ....If you didnt have the gate?
Who did your cage if you dont mind me asking?
going with a bigger single or changing the 66 to a T4 housing?
What kind of gate did you go with? Engineered diesel? They make an awsome wastegate for diesels
Mike Hiel did my cage. He does tech at Castrol raceway in Edmonton. very reasonable. $1200 for a 6 point bar (mild steel) installed with drivers swing out. Guaranteed 10.00. pedestal did not come with block off.
4202 and then next winter putting a GT55 under it.
nathan is going to have a kit, but probably not before the season starts.
There are other options....
Looks good. I take it the wastegate outlet on the pedestal is 38 mm?
