LLY: Updated motor build
THduramax
Will it ever end!
Aug 15, 2012
407
Flaherty, ky
ImageUploadedByTapatalk1372947460.200105.jpgImageUploadedByTapatalk1372947484.614710.jpgImageUploadedByTapatalk1372947506.115862.jpgImageUploadedByTapatalk1372947521.412247.jpg. It's been a while since I updated but it'll be on the rd next week. Some added stuff we did was take out all the stock fuel lines. Added a fuel block in in Place of the glow plug control module and all 5/8" fuel lines. No fuel lines running to ficm. Kept it in original spot.. We'll see how it holds up to heat... Shouldn't be any problem. Running a box stock s472 for now.... Possible compound setup in future idk... Had injectors honed and balanced out from the 60% they were to 100%. On first attempt to start we bumped the key 3 times to prime fuel.. Then cranked for about 5 seconds.. Fired right up... Smooth as a baby's a**. Only thing I'm waitin on is the hot side ic tube to be cut and flanged and the intake to be cut... 850hp should be a good target... She's got it in her.. More pics and finished write up to come.
THduramax
Will it ever end!
Aug 15, 2012
407
Flaherty, ky
ImageUploadedByTapatalk1373035485.544855.jpgImageUploadedByTapatalk1373035510.879811.jpgImageUploadedByTapatalk1373035547.276900.jpgu can see the return lines and feed lines.. It uses bracket where glow plug module was.. To the right of the brake booster I t'd the fuel supply to feed cp's... Bigger lines and a cleaner look.. Louis is a good machinist.. He said he can hook anybody up if try want a block.
