We recently picked up an 03 duramax that was having high rail pressure issues when we picked it up. We got the truck back to the shop, changed the regulator, cleared the codes, and is still idling around the 23,000psi mark. Here's where it gets weird; no codes came back. We then thought that the ECM was bad, so we replaced it as well with no luck. Figuring the new regulator was bad, we chose to switch with another new regulator- same thing. Started testing voltage, and it runs ~1 volt at the regulator with just the key on. As soon as you start it, it goes down around 0.05volts. Thinking it was maybe a wiring issue, we jumped the wire from the ECM straight to the regulator, still same thing. Tried testing voltage with a spare cp3 just sitting on the top of the engine and it still drops volts. Tried switching the FICM as well with no avail.
When driving the truck, the rail pressure constantly stays at 23000 or whatever it is, no matter what the desired is.
This has my mechanic and I both stumped, so I figured I would look here for advice. Let me know if you have any questions or suggestions.
Thank you
-Drew
Thank you
-Drew
