anyone? i i know i have to reflash but idk how to actually do it.
Ferm should be chiming in. I think he recommends all lb7’s change to the 6006 OS, which can be downloaded and flashed in.
OP, do not do this.
Send me the vin number and I can get you the correct OS for your truck.
I recommend all 01/02 run the 6006(unless running an edge), 03-05 MUST use the stock base file. I would not put a tech 2 on it to flash it if it were mine, way to many corrupted lb7 ecm's from tech2 flashes(grant it 01 was the worst, but 02-04 are still fickle creatures. If it's locked you'll want a bench harness and flash it with a V2, and you can load it with a full flash iirc of your choosing. Just make sure it isn't corrupted 1st.
is there a company i can ship my ecm and tcm out to and have them flash it back to stock?
The problems I believe were with operating system mapping and dsp5 switching via the edgeHave you had trouble with the edge monitors with a 6006 file? Buddy with an 01 that we used a 6006 file for the dsp5 base has the cts2 monitor and the fuel level / boost do some weird stuff. We kind of chalked it up to being the monitor as it was doing funny stuff (not fuel/boost) when it had the factory base file even
Oh, thanks for the correction. Sorry to spread bad info! Out of curiosity though... I full flashed an 04 with 6006 OS. Should I pull that out?
I would. I only use the stock base file for 03-05 trucks so things like the oil pressure gauge work properly, cruise, power windows, and ac.
