got a 03 here that wont turn over! I can jump power to crank fuse and get it started that way but not with the key. there is NO dash under the PRNDL with check engine, ABS and parking break (parking break is NOT on) lights on. read codes using my edge insight and found P0380 (been there forever and not concerned) and a U2106 which I believe is the cause of all this. It WILL shift into park, reverse and drive but with a nasty clunck (shifting into 3rd which is the default gear with no power to trans). I took the tranny pan off and removed internal harness to clean and inspect but everything was perfectly fine. replaced the NSBU less than a year ago with the updated tan version so I dont believe thats the problem. Checked all wires on NSBU for continuity/B+/ground and everything was good. DOES ANYONE HAVE ANY IDEAS WHATS UP?
