I also had flash probs with the new efi update.Flashing stock tune back into the truck after swapping the stocker back in with 100% factory electronics and took 7 tries then took after an 8 min flash.same truck wirh previous version was 3 min max.
There has been no reported issues regarding flash times between releases. What software versions did you notice this change? (Please don't say the last 2, I have no way of knowing what the last 2 versions you installed were, so please list version numbers)
What software and flash method were you selecting for your comparisons?
V7 pass-thru full flash, or cal flash?
V8 BBX full flash or cal flash?
V8 pass-thru full flash or cal flash?
Fwiw, V7 flash speeds cannot be compared to V8 for measuring version performance. The flash methods developed for V8 are about 40% faster than V7. (controller dependent - some are even faster than that, others can be a bit closer).
If the issue you are reporting is with V7 could you please test your flash time with V8?
Cheers
Cindy
