u0100 lost comm ecm pcm
GeneralTJI
Turbo Todd
Jun 1, 2010
1,272
Colorado
What was the deal for you??
I occasionally have gotten this code.. no real pattern to it... haven't seen it in quite a while but who knows if/when it will come back. Never caused any actual issues (other than putting the tranny into a mode similar to tow/haul)
revedupforone
Jan 2, 2011
U0100 code
My duramax recently threw a few codes U0100 lost com. w/ ecm/pcm module A.
P0700 trans control system malfunction
P0181 fuel temp sensor malfunction
P0116 engine coolant temp malfunction
I found a loose neg. cable at the left battery. Cleared the codes and that fixed the problem.
jarheadhunter
06 DMAX 100+ HP
Mar 29, 2011
Utah
My truck is throwing up the lost comm ecm pcm and p0700 trans ctrl sys error.
I checked the negative battery cable thing and thats a no go. How do you test the fuel temp sensor.
GeneralTJI
Turbo Todd
Jun 1, 2010
1,272
Colorado
I tightened up the pins on the TCM connector and I haven't seen this since. Might be worth playing with, also may want to look at the main bale connectors.... (i also cleaned and re-grounded the wiring for the abs module- the grounds that run to the frame under the driver, at the same time as tightening up the TCM connectors)
Hope this helps,
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
well I figured out the p0113, I forgot to plug in my maf sensor lol. Plugged it back in and tightened up my loose pass negative cable (yes I thought it was odd too that the other guy had a loose neg cable). Will need to start it in the morning to check and see, too late tonight, ain't nobody got time for dat.
