Both up pipes need to be gated. Why not tie it into the pedistal?
x2 pedistal is the easiest, just make sure its not a true divided pedistal or it will be the same as doing one up pipe
my pedisatal and spacer are divided, i could run 2 gates but i think the one larger gate will flow more, i'm running a tight a/r on the small turbo
