So my truck has a 480 over 366 40 over injectors and 40 over pump I feel like the 480 is hurting the performance is this possible do u think the truck will make more power with just the 366
It was the change from the 74mm turbine to the 70mm turbine wheel that made the big difference in his swap to the 364.5fmw.X10
Search posts by coker6303 he has played around quite a bit with his 366/480. he ended up going with a 364 IIRC
It depends on the fueling but could see mid 70's for boost.The 366 is a gated htt charger I no the question sounds like it makes no sense but I feel like the truck should be a heck of a lot faster. Fastest pass was 12.1 at 111 keep in mind it is 2wd and 60 foots aren't the greatest but my stock lb7 went mid 12s on tuning. What boost should I be seeing out of the twins thanks guys
