Finally. We are going to run PPE twin (compound) turbochargers on Casper for development purposes. PPE is trying out a custom twin setup with help from Garrett to see how high we can turn it up. I can't say what the exact configuration will be, as it's still a prototype setup.
To support the additional HP, Mike L of Inglewood Transmission is trying some new prototype clutches on the C3, and some new hard parts as well. It will be based on a 5-sp Allison.
Goal is 900+ rwhp over a wide powerband, and a 9 second ET on fuel-only at 6700lb. Currently the GT42 Mag setup is making 798rwhp uncorrected, and the GT4202R setup is 754rwhp.
The engine will be our El Mirage engine, which is LBZ heads, LLY block, LLY ECM and 10% over Dynomite Diesel injectors. SoCal Diesel high speed valvetrain, Crower rods, delipped pistons are the internals, with a PPE Dual CP3 system running 2 Wicked Diesel pumps supplies the fueling.
I will retune it using EFILive for both engine and trans tuning to get it dialed in.
I will post more as info becomes available.
